tC2 Spec-D LED Tail lights/ Headlights with LED Strips..
Old 05-25-2013, 03:02 AM
KILLER's Avatar
Default tC2 Spec-D LED Tail lights/ Headlights with LED Strips..
These are the same K2 Tail lights but I rewired them so I can have Dual Red LED bars and amber turn signals. I'm still not too sure about the Reverse lights.
Also wired some LED strips from superbrightleds.com and 5,000K MORIMOTO HID KIT
KILLER is offline
Old 05-25-2013, 03:12 AM
Delorean2006's Avatar
Originally Posted by KILLER
These are the same K2 Tail lights but I rewired them so I can have dual red led bars and amber turn signals. I'm still not too sure about the reverse lights.
SPEC-D SCION TC2 LED TAIL LIGHTS - YouTube
2012 Scion TC with Lexus style DRL - YouTube
the lights look great! im actually a little iffy about the white reverse strip myself and which morimotos did you get? 35 or 50w? im interested in replacing my DDM tuning HIDs with those
Delorean2006 is offline
Old 05-25-2013, 03:35 AM
KILLER's Avatar
They are 35w. I dont like 55w because they create too much glare and it also washes off the bulb color.
As for the reverse lights, I might use another type of light and relocate it. Can't find the right spot yet.
KILLER is offline
Old 06-14-2013, 01:23 AM
CAtC12's Avatar
i love those tail lights. especially the reverse lights
CAtC12 is offline
Old 06-20-2013, 06:04 AM
adanruiz2010's Avatar
Question about the wire Style for the front LED strip been looking into this but not sure about getting the wiring done correctly and Nice Tail Lights there epic i love mine just got them like a month ago!
adanruiz2010 is offline
Old 07-05-2013, 10:19 PM
mikellertc's Avatar
Did you have problems with leaks and condensation with the spec d taillights? I'm considering getting them, but been hearing lots of bad things about it not fitting right and people getting leaks.
The LED strips looks sick by the way!!
mikellertc is offline
Old 07-05-2013, 11:16 PM
xaxdect's Avatar
No missing those brake lights!
xaxdect is offline
Old 07-07-2013, 03:59 AM
itsleeyo's Avatar
Was it difficult to rewire the brake lights and the signal lights?
itsleeyo is offline
Old 08-14-2013, 07:53 AM
KILLER's Avatar
Rewiring is easy, if you have basic skills with wiring then you good to go.
There is only one ground wire for these tail lights so just isolate it and work with the other color wires. cut the turn signal wire half way and splice it into the brake light wire, this will activate both LED rows when the brakes are applied.
The loose wire that is the turn signal will now be spliced into the upper reverse light wire. The Reverse (+) wire will now be cut off with no power. you can now splice the LED strip's (+) wire to the existing Reverse light (+) wire.
As for the Ground it's the same wire for all the lights.
TIP: I used a 12v battery from my drill gun and some crocodile wires to test for power before putting the tail light back ion the car.
KILLER is offline
Old 08-14-2013, 03:00 PM
itsleeyo's Avatar
Thanks for the reply. Do you have the link to purchase the LED strips that you are using?
itsleeyo is offline
Old 08-14-2013, 03:16 PM
KILLER's Avatar
Yes they actually have new strips that come silicone covered. The ones I am using have a clear rubber tubing which makes them bulky and difficult to fit.
Here is the link
http://www.superbrightleds.com/morei...s-series/1542/
*Get the led in NATURAL WHITE with black finish.
KILLER is offline
Old 08-14-2013, 03:32 PM
itsleeyo's Avatar
Are the ones that you linked silicone covered?
How many would i need to purchase?
Do I need to purchase orange light bulbs to replace the reverse light?
Thanks for your help again
itsleeyo is offline
Old 08-15-2013, 11:45 PM
KILLER's Avatar
I used 2 strips per side. They are thin enough to fit under the headlights. Make sure you go easy when you curve the led strip , the twisting can cause some of the diodes to burn out.
BTW...I just received the new waterproof led strips in NATURAL WHITE with black board and tbey are too blue for my taste. I will be returning them for the correct color. I'm sure superbrightleds sent me the wrong color.
As for the turn signal bulb I used a Cree High Power Amber LED bulb
KILLER is offline
Old 02-11-2020, 11:31 AM
Administrator
Administrator
MR_LUV's Avatar
Great Tips!
Becomes a Sticky
MR_LUV is offline
Old 03-04-2024, 08:35 PM
blacktc12's Avatar
Is the right side the break or turn signal
blacktc12 is offline
Old 09-03-2024, 12:03 AM
James007's Avatar
How do you isolate the ground wire?
James007 is offline
Old 09-03-2024, 01:51 PM
Super Moderator
SuperMod
MileHightC's Avatar
Break out the old multimeter or look at a wiring diagram...
MileHightC is offline
Old 09-03-2024, 02:23 PM
James007's Avatar
I have very basic multimeter skills. I can find the wire for signal and brake with my multimeter, but how do I tell which one is gound when it doesn't carrry power for the multimeter to detect? I feel dumb since I can't even find the answer through a Gogle search, which always tellls me what I need to know, but not this time.
EDIT: Thanks anyway. I'll figure it out like I always do. Thanks!
James007 is offline
Old 09-04-2024, 02:20 PM
Super Moderator
SuperMod
MileHightC's Avatar
Ground wire will carry 0 ohms resistance...or pretty close to 0.
Find Ground with a Multimeter
Old Yesterday, 07:59 PM
James007's Avatar
I rewired my Spec-D's and I love them!! I liked them before but I thought that a single row of 5 LED's on each side for a brake light just wasn't enough, just wasn't safe enough.
So I rewired them and protected them with shrink wrap and then electrical tape to be on the safe side. When I first installed them I kept and re-used the thick rubber gaskets that were on the stock lights so everything is gonna stay nice and dry.
I kept and put the stock lights into storage "just in case". I really can't understand the people that install Spec-D's then sell the original stock lights. Parts are getting harder to find as time goes by. They will regret it one day.
Anyways, I changed out the reverse lights and put amber LED's in their place, and they look like they may actually be too bright .... lol !!
As far as the left over reverse light wires, I used the drivers side for my back-up camera which has 6 bright LED's, so those are my back-up lights now, and the passenger side I just left clipped.
Thank you very much for this idea. I think it's fantastic!!
I'm adding a couple of photos. Please ignore the big shadow I made on the back of my car. lol !!
I'm going to take new photos soon.
Thanks again for a fantastic idea!!
I'm much happier with my Spec-D tail lights!!
James007 is offline
Dominyc
Scion tC 1G Aero & Exterior
11-22-2015 07:23 PM
ej1987
05-09-2015 05:17 PM
CHPRBOX8
03-07-2006 11:58 AM
XBOXXX
10-10-2005 11:37 PM
eight08xb
08-05-2004 02:04 AM
Quick Reply: tC2 Spec-D LED Tail lights/ Headlights with LED Strips..
