2011-____ [ANT20]
Water in the Engine Bay
Old 07-05-2024, 02:49 AM
Syn19's Avatar
Default Water in the Engine Bay
Hey all,
When you open the hood to clean the engine and whatnot, is there anything that needs to stay dry?
I'll be using a hose and probably a pressure washer.
Syn19 is offline
Old 07-05-2024, 07:30 PM
Super Moderator
SuperMod
MileHightC's Avatar
Electrical connections shouldn't take a straight shot form a pressure washer, filter if you're running a CAI, make sure coil pack/spark plug holes get blown out with air...unless you've got years and years of grease buildup, I'd spay with a Simple Green or Purple Power mix, let it sit for 5-ish, use a few brushes of different sizes to scrub and then gently rinse or step-back or dial the pressure washer way down.
High-pressure water and engine bays are a bad combo...I can get an engine bay looking like-new with the above method and some engine detailer spray or 303.
MileHightC is offline
Old 07-18-2024, 07:31 AM
Syn19's Avatar
Right on.
Much appreciated.
Syn19 is offline
AAG
20
08-19-2011 09:31 AM
macgadget
29
01-08-2008 05:04 AM
Sniffs
Scion tC 1G Aero & Exterior
21
12-28-2007 12:41 AM
vFePiC
25
03-24-2007 08:57 PM
xBeepbeep
10
05-19-2005 01:10 AM
Quick Reply: Water in the Engine Bay
