replaced weak battery, now won't start - no click, nothing
Old 09-29-2024, 10:33 PM
sedond's Avatar
Default replaced weak battery, now won't start - no click, nothing
hi!
so, my '04 xb manual , w/~212k on it shares use w/another xb and a fiat 500, as well as a few motorcycles. which means it sits a lot. plus i broke my foot, and nothing was getting any use for over a month. when i went to start the '04 a while back, it was dead. it took a charge, and started right up. but it went dead a week later, and i knew the battery was long overdue for a replacement. which i installed today. except now, i get nothing. new battery is good, all electronics, accessories, etc are working, and fuses are fine. when i turn the key, there isn't even a click. you can hear the injector pump, but that's it. wtf? what did i do? i simply pulled out the old battery and installed the new one.
any help, experience w/something like this, etc, would be greatly appreciated
thanks,
doug s.
sedond is offline
Old 09-30-2024, 12:03 AM
LULU's Avatar
Did you check the fuses? Clutch sensor? Lastly I'd see if the starter was good. Hope this helps.
LULU is offline
Old 10-01-2024, 07:22 PM
IRLvr's Avatar
Check your main ground wire too!
IRLvr is offline
Old Today, 12:04 PM
RichBinAZ's Avatar
A phone pic of the installation might shed some light.
Do you have a battery tester? Harbor freight sells one for about $40. Easy to use. May have got a bad battery
RichBinAZ is offline
weenlette
09-27-2022 05:14 AM
Studious
9
12-05-2020 08:18 PM
jdo93
11-03-2018 03:46 PM
ANightDriver
09-29-2009 04:47 AM
dmpsk8
07-06-2008 07:34 PM
Quick Reply: replaced weak battery, now won't start - no click, nothing
