Cabin Air Filter (Homemade)
I just replaced mine after only three months - it was totally and unbelievably dirty!
Don't wait - install one now!
BTW, I think the wire should go on the down side, but I'll have to double-check that one.
I should have taken a picture of it - next time I will...it's truly amazing how bad it looked.
Scott
Scott
This is interesting....my electronic parts catalog shows a cabin air filter case (aka tray), but no filter.
My fast moving parts book says:
"The Scion tC cannot be retrofitted with a Cabin Air Filter or Case part number due to cooling system operations."
The message is so vague. I don't see how a filter could disrupt and cause harm to the HVAC system - unless you installed the filter incorrectly which would put stress on the fan.
All I can say is that I'm breathing fresher air and apparently (based on the previous post), the filter is grabbing a lot of contaminants producing fresher air.
Originally Posted by DieselTC
YES, I can confirm this... it flows from the top, down. I put the air on and held a piece of paper to make sure.
BTW, forgot to mention earlier and while we're on the subject of clean air... Before I installed the new filter in I also used a product from a German company called Klima Cleaner. It's made by 1Z (or 'einszett' in German). It cleans out the evaporator core inside the dash (that's where all the mold and bacteria are because of water condensation and dirt buildup). Anyway, with that applied and my new filter, I'm looking forward to easier breathing during allergy season. I just wish I knew about the filter a couple of weeks ago before the pollen count started to skyrocket!
Here's a pic and link to the product.
Great DIY I'm gonna try to get this done over the weekend. By the way, what is the evaporator core and how do I get to it?
Link: http://www.1z-usa.com/sys-tmpl/plasticvinylrubbercare1/
Descript:
Klima-Cleaner 250 ml (8,5 fl oz)
- Removes bacteria and fungi from air conditioning units and ducting.
- Reduces allergens for clean, healthy, and fresher smelling air.
Don't mask odors with fragrances -- treat them. Klima-Cleaner is an effective means for removing odors from the air conditioning unit by eliminating odor-causing bacteria, fungi and other germs. Works by effectively cleaning the evaporator -- the source of the problem. Simply insert included spray hose into the center air vents in your vehicle's interior and spray. Allow to work for 30 minutes. Creates a healthy and fresh smelling environment that lasts for months.
Descript:
The evaporator is located in a box within the dashboard (behind the glove box). From the box, the ventilation tubes extend out to the dashboard vents. Refrigerant flows through the evaporator which then pulls heat and moisture from the air flowing over it. The moisture collects on the tubes (like condensation on a glass of ice water) and drops to the bottom of the box. At the bottom of the box is a drain plug that's connected to an evacuation tube that extends to underneath the car around the engine area. That's why you'll see a puddle of water forming underneath a car that's been running its a/c.
The problem is that this moisture that build up in the box is a great place for mold, fungus, etc. That's why it ends up smelling the air coming out of the vents.
So this stuff works by dispensing a thick foam that goes to the evaporator and like soft scrub kills the mold and fungus that grows on the evaporator tubes and within the box.
So much valuable info, I've had more of this damp mold smell when I turn on my air in my tC more than any other new car I've been in. Usually this smell developes after a few years but I noticed it in my first summer. Gotta get this done before it gets hot around here. I love this furum!
Even toyota says it can't be done:
http://www.toyotaownersonline.com/pd...rfilters06.pdf
However, as part of my 15,000 mile service I just had a new one put in. Using the directions in this thread I opened it up to make sure they really did it. There is a new filter in there, and it looks like an original toyota part.
I have a bunch of those fiberglass spun one's lyin around, Ill grab a pair of gloves and make me one, although Ill try to double it up as the fiberglass ones arent exactly the best filters. Hopeflly should work without a hitch, Ill let ya know.
I'm ____ed though because the filter does such a gret job and comes out incredibly cruddy. All my vents, etc. are so clean that I can't imagine running without one, but if it's going to cause trouble, I'm not sure I want to leave it in
Scott
this issue re: the tC has been discussed in several threads. this thread from last summer shows what i use. it is a filter called "web absorber" (home depot) and uses a fiberglass filter element and a charcoal sheet with a plastic cover that when cut to fit, fits neatly under the tabs of the filter housing (this part i use over and over).
as told to me last year, toyota's issue with the tC utilizing a filter was the poor ac performance that caused the tsb; they didn't want to impede air flow to exacerbate the problem. since the ac fix there apparenly is no issue. "web absorber" has minimal air flow obstruction.
photos:
http://img106.exs.cx/my.php?loc=img1...filter28do.jpg
http://img143.exs.cx/my.php?loc=img1...filter15kx.jpg
photos:
Originally Posted by CirrusDriver
Alright, so I just did the install and I noticed that either way I put the filter it restricts the air flow just a bit. Anyone know if that's normal?
