tC Tech and DIY Info for the Scion tC
Clutch Pedal Stop Install
Old 10-30-2005, 10:36 PM
  #41
mprabidhamster's Avatar
if you are having troubles with the disengage button, just clip the wires coming from it and wire it up to a push button switch that you can install in your dash. That way there will be no problems. When you start your car all you have to do is hold the button.
mprabidhamster is offline
Old 10-31-2005, 01:37 AM
  #42
or even better you could stick a rubber stopper on the clutch pedal tab, so the button is un-altered
Old 11-01-2005, 01:47 PM
  #43
JINeration's Avatar
i think imma try this mod shounds likea great idea
JINeration is offline
Old 11-02-2005, 03:00 AM
  #44
JINeration's Avatar
dude i cant find a freakin elevator bolt newhere i went to home depot and loews this is ___...
Old 01-16-2006, 09:53 PM
  #45
stl_tc_king's Avatar
myself, along with three other manual tc's in our club tried this mod yesterday.
I love it! elimanates all that extra nonsense play in the clutch. It took about 10 minutes and cost less than a buck.
stl_tc_king is offline
Old 03-23-2006, 02:52 PM
  #46
moots13181's Avatar
Default Is it possible to do this mod w/out tapping anything?
I don't have and don't know how many ppl might have a tap set. I'd love to get one though, both metric and english. Any idea how much they run?
I'm being lazy, I'll prolly just look it up right after this, but post up a response anyway, maybe someone else can use the info.
Great write up, awesome pix, just the right amount of detail in the step by step... dude you should go pro and work for a magazine!
moots13181 is offline
Old 03-23-2006, 03:06 PM
  #47
aarontrini85's Avatar
Default Re: Is it possible to do this mod w/out tapping anything?
you can get the one you need and turn it with pliers for like $1 or a small set would be about 10 bucks but shop around
aarontrini85 is offline
Old 08-11-2006, 06:42 AM
  #48
ignitionr34's Avatar
reviving an old thread!! but i'm got almost all the supplies for the mod cept for the machine screw 4-40, i've only can find a 3/4 inch long one not a 1 inch, would that be fine???? i went to murreys and hompe depot, but they dont' carry one inch!!
ignitionr34 is offline
Old 08-11-2006, 03:01 PM
  #49
raamaudio's Avatar
Go to your local Ace, etc, small hardware store chain, most have alol more items than the big stores when it comes to nuts and bolts;)
Not sure if the 3/4" would work or not.
Rick
raamaudio is offline
Old 08-11-2006, 06:25 PM
  #50
is there a difference b/w a regular bolt and an elevator bolt because i asked the guyz that worked they're and they don' even know what that means
Old 08-14-2006, 05:49 PM
  #51
sdparks's Avatar
The elevator bolt has a large flat head, about 1" in diameter. Without the large head, I don't know how much contact the bolt head would make with the pedal arm. You don't want to risk having the pedal arm slip off of the bolt head, because the pedal could get stuck.
sdparks is offline
Old 09-30-2006, 07:22 PM
  #52
Yablargo's Avatar
The guy who said just put an extra stopper on it has the right idea. I was really bored and tired of extra play (not as much as my tC tho! ) in my Si's clutch, and got to looking. Theres like 1cm of room behind the stock clutch stop and the firewall soooooooo... either sticking a new bolt in or just adhering a few of the feet on is the way to go.
Yablargo is offline
Old 11-19-2006, 04:29 AM
  #53
bigyankee's Avatar
Going to give this a try. my first custom mod. do things like this void the warranty?
bigyankee is offline
Old 11-19-2006, 06:04 AM
  #54
soros151's Avatar
watching, and I don't think this will be voiding any warranties.
soros151 is offline
Old 11-19-2006, 08:27 PM
  #55
Rob_Tampa's Avatar
I can vouch for the Magic Sliders that Acsilva84 used (Page 2). I did this mod about eight months ago, and it hasn't given me any trobles. The nice thing about them is that they allow for slippage between the Magic Slider and the plastic switch so its not putting any undo lateral stress on it.
Rob_Tampa is offline
Old 11-19-2006, 08:43 PM
  #56
InfideL's Avatar
Magic Sliders is a good idea makes it much more simpler. I just hope the plastic won't crack after long term use.
So do we heighten the clutch stopper and the disengagement switch by the same amount?
InfideL is offline
Old 11-20-2006, 02:14 AM
  #57
Tcguy85's Avatar
i just did this mod and it's awesome, i only drove my car around for a couple minutes to test it out but it seems great so far. i'll post again tomorrow after i drive to work and back with it.
Tcguy85 is offline
Old 04-24-2007, 02:59 AM
  #58
ElDiablo17's Avatar
Can ya show a pix of the magic slider installed in your car? Please? Thanks
ElDiablo17 is offline
Old 07-31-2007, 01:28 AM
  #59
Matt_Burgess's Avatar
I think im gonna try this mod out, i hate the long throw of the clutch pedal..
Matt_Burgess is offline
Old 07-31-2007, 03:11 AM
  #60
xIxAMxHOLLYWOODx's Avatar
I did not realize how old this thread was! Anyway, I pulled this mod off right now. But did a few things different. I didnt tap the hole, I just drilled through it to accommodate a larger bolt. I didnt use an elevator bolt either, just found a bolt with a WIDE head and used that. Used two nuts, a flat washer, and a lock washer. The flat washer and one nut on the "head" side of the bolt, and the lock washer and other nut on the back side. It was kind of difficult to get the nut on the back side, but with patience and skilled fingers I got it to thread. Then it was just a matter of adjustment.
As far as the neutral safety switch goes, I just got a wire tap and squeezed it together (grounding the two wires to each other). I was never for disengaging the clutch to start the car.
Pretty easy install, took all of ten minutes! Gonna let the guys in my club know about this one...
And like someone said, the clutch is now an on-off switch. No middle ground, I love it.
xIxAMxHOLLYWOODx is offline
Quick Reply: Clutch Pedal Stop Install
