Clutch Pedal Stop Install
#81
I'm thinking I should buy / install a spare OEM shifter (Have a TWM installed) and bring the thing to the dealer to check out. Have a feeling they're going to tell me it's fine tho. Guess what I really need is someone to push the pedal while I watch the slave to see if it's really moving like it's supposed to be. It's gotta be my car, seems everyone has the extra play. Hmm..
#85
Originally Posted by TTCCC
Not sure if this has been discussed. But is there a way you can start the car without having to push down the clutch ? I did this with my old car but am new to scion t/c's 08
#86
Just got done doing this mod and my shifting is 100x smoother, especially going from 1st to 2nd gear. It was pretty diffucult to reach my arm in the small area and it took me alot of trial and error to get it adjusted to the right length but it was difinitely worth the time and the 4 bucks.
#88
nice.. i might do this.. i have TRD clutch.. but the biggest problem is.. it feels spongy when i press the clutch .. when i start pressing the pedal in the first half inch it feels too soft.. after that its really hard and nice (sporty) what can i do with that first inch? is there a way to adjust the pedal there?
#90
i did it.. im not really sure if i like it................................
well i got trd clutch already so its not like yours guys.. but.. it feels a little bit ...well how to say this.. :tacky... sloppy?
#91
i couldent find an elevator bolt so i welded a fender washer to the 1/4 20, i think if u use to small of a bolt in the existing hole in the write up, there isnt enough contact with the clutch petal touchy thingey, u need a bolt with a large top, thanks alot for the mod ^_^
#96
I know this is a super old thread but i'm in the process of setting up this mod. What is the best way of figuring out how far in your clutch has to be so that is is not slipping when you shift? i was thinking finding a flat spot and listening really closely, I figure there must be a more exacting way. Thanks for any help.
-Alex
-Alex
#97
Originally Posted by silverstreaktc
DOES THIS WORK WITH AN AUTO?
-Alex
-Alex
Let me know if that helps at all. I can make some diagrams if need when I get home.
#98
Just did this 2 my car about 10 mins ago... Did everything the exact same way except i used 2 thick Magic Sliders on top another and taped them together to the clutch pedal with electrical tape just in case they don't fall off...
