tC Tech and DIY Info for the Scion tC
DIY: DME torque damper (with pics)
Old 02-26-2008 | 08:11 PM
ippskidder's Avatar
1UP Crew
looks very close to the ingalls stiffy.
Nice write up ^^
This one comes with bushings, that a nice touch.
Old 02-27-2008 | 01:54 AM
Aroddalobster's Avatar
thanks, and yeah, i like how we could change out bushings depending on how stiff we want it, even though i'll probably never change it to the harder bushings.
Old 02-27-2008 | 04:11 AM
NonStopTuning's Avatar
Its very nice to have the option to adjust the ETD to your needs. The DME ETD provides just that, with the different bushings.
Old 03-04-2008 | 01:26 AM
tCeeder's Avatar
not to hijack your thread, its a great DIY - just thought i'd add a few more detailed shots...
this is what the bracket looks like when properly bolted to the engine. note the order of components:
bolt -> washers -> bracket -> metal cylinder -> engine
this is the strut bracket correctly installed before bolting it down:
if you have a strut bar, you'll need to put some washers on the right strut (if facing the fron of the car), to fill the gap that the strut bracket creates on the left strut:
aaaand some random pictures....
represent that
great mod, i recommend it highly. shifts feel smoother with the ETD. cabin noise is a little more but not too bad, at idle is when its the worst.
Old 03-04-2008 | 02:53 AM
ahh filling in what i missed. i just did the same thing this weekend, except using 4 home depot washers on both strut bolts. also, while i was going washer crazy, i laid down 1 on each bolt under the bracket for the ETD on the passenger's side, because i noticed that it isn't level. thanks for the add-on!
edit: nice engine cover btw tceeder
Old 03-04-2008 | 03:00 AM
tCeeder's Avatar
yeah, i got those at advance. i only used one on each as they were pretty thick to begin with. i used the black bushings, if the vibration/noise isnt crazy bad i might put the red bushings back in.
Old 03-04-2008 | 03:11 AM
frenchaj09's Avatar
Scion Noics
this belongs in the Tech section...... Moderators if you please!
GJ btw, nice writeup. Convinced me to get one.
Old 03-04-2008 | 04:43 AM
Garage1217's Avatar
Looking good man! Nice writeup.
Old 03-06-2008 | 05:23 AM
thx and glad i could help!
Old 03-07-2008 | 04:59 AM
Excellent thread. Two thumbs up!!!
Old 03-09-2008 | 04:31 AM
jetlounge's Avatar
Very similar to the ingall's etd...
although there is nothing in this diy about setting the pre-load which accounts for cabin noise.
ETD write-up with preload adjustments and considerations for s/c installations:
http://blog.scionxtc.com/blogs/archi...ue-damper.aspx
https://www.scionlife.com/forums/viewtopic.php?t=161394
Old 03-09-2008 | 06:33 AM
darkscion's Avatar
so hows the car hook up now when you launch it,better?
Old 03-09-2008 | 08:28 AM
Nick06tC's Avatar
Good write up!
Old 03-09-2008 | 10:00 AM
Originally Posted by Nick06tC
Good write up!
thanks!
to be honest, i'm not sure... i never launch hard.. or i rarely do, but i could definitely feel a lot more power to the ground.
I'll have to try those if i ever get annoyed. but as of now, i'm totally fine with the extra engine noise. i actually like it. and a quick fix for me would be to turn up my stupidly loud subs lol. but thanks for the links. i'm sure it'll help a lot of people with even this etd.
Old 03-30-2008 | 05:50 AM
AcidDrop's Avatar
gonna have to bump this for whenever i get one so i can remember how to install it.
Old 03-30-2008 | 06:07 AM
frenchaj09's Avatar
Scion Noics
x2^
Old 03-30-2008 | 07:15 AM
sweet glad i could help. should be a very simple install.
Old 03-30-2008 | 08:06 AM
Thanks again Aroddalobster and tCeeder. Great pics and info for a great ETD!!!
Good luck and have fun with all your projects guys!!!
Old 04-01-2008 | 02:28 AM
ToyoCel's Avatar
I have the ingalls torque damper and was talking to one of the vendors at the irwindale triatholon a few weeks ago. I told him that i still had alot of wheel hop and that when I took off from first i would year a loud clank noise. He told me i needed to tighten up my torque damper. I havent done it yet though because the intructions i got with the damper was "DO NOT ADJUST LENGTH". Has any one heard of "tightening" the torque damper. It doesnt have to do with the bolts. They are super tight.. trust me!!
Old 04-01-2008 | 08:27 AM
weeloTC's Avatar
whats with the stack of washers on the bracket that connects to the head, are they suppose to be like that, why not just the right size bolt, just wondering if you guys were sure it was installed right?
Quick Reply: DIY: DME torque damper (with pics)
