tC Tech and DIY Info for the Scion tC
Dome Lighting Install
Old 10-22-2006, 12:31 PM
  #301
tC squad
eLpReSiDeNtE's Avatar
ok problemsolved i went back to my car found the dome fuse which is 7.5 and yes it was blown since i didnt have a 7.5 fuse available i replaced it with a 10 fuse....hopefully this wont be a problem.....everything seem to be working fine.....all lights light up!....will post pics tonit.....i got my door light superwhite my map lights and my rear dome are UV to match my underdash UV cathodes.....
eLpReSiDeNtE is offline
Old 10-22-2006, 01:39 PM
  #302
V0RT3X's Avatar
must be a blown fuse
look under the fuse box and look for DOME
V0RT3X is offline
Old 10-22-2006, 02:27 PM
  #303
Scigon7's Avatar
i just threw in my led lights they look pretty cool..one of these nights ill take some pics and post them up. it only took me 10 min to put them in
Scigon7 is offline
Old 10-23-2006, 09:11 AM
  #304
SquallLHeart's Avatar
go to store.. buy 7.5A fuse.... replace it using the correct value.
unsafe to use higher rating.
SquallLHeart is offline
Old 10-23-2006, 08:43 PM
  #305
Magnus213's Avatar
I know everyone was holding their breath, but my correct festoon bulb just arrived from superbrightleds.com, so my dome lighting makeover is complete! Now I have a spare white festoon bulb... is there anywhere else in/on my car I can put this?
Magnus213 is offline
Old 10-23-2006, 09:20 PM
  #306
tC squad
thanx squall.....will do tomorrow....but how unsafe is it really???.....its basicaly the next value up.......once again you are the pro so i will buy a new fuse...im just curious to know wat exactly is the difference
Old 10-23-2006, 10:28 PM
  #307
the wires that are put into the car are rated to handle a certain amount of amperage.. when the fuse blows.. it prevents damage to that wire and then possibly starting a fire.
having that wire still continue to handle a lot of current without a fuse blowing (because the fuse is higher)... is yea... risky.
most auto stores carry mini-fuses, however most if not all are not the low profile ones like the stock ones (i think you can only buy them at the dealership, online or the company directly)
but.. the higher profile fuses will still fit in the slot and will stick out. it's fine if the fuses are in the engine bay fuse box, but if one of the fuses blow out in the dash one, with that higher profile fuse.. the cover's not gonna go back on.
yea.. i know it's just 2.5 more amps... but whatever... i'm picky..
Old 10-23-2006, 10:31 PM
  #308
tC squad
^^^^^lol....yeah i know your picky.....the dome fuse is in the engine bay.....ill change it when i can get my hands on a 7.5 mini fuse.....i asked my parts department and they had no idea wat i was talkin about....goes to show!!!
Old 10-24-2006, 08:55 PM
  #309
Magnus213's Avatar
I installed my festoon bulb in the rear trunk light mounted on the driver's side of the compartment. Here's my no-picture mini walkthrough:
1. Grab a small flathead screwdriver, like you used for the dome lights. Use it to pry at the edges of the light cover, again like you did with the dome. The entire light assembly will pop out rather suddenly.
2. Release the wire connector deal and you should have the light assembly free in your hands. There is a long, grey, C-shaped kind of cover held in by two little tiny tabs on each of its long sides. Once again, use the screwdriver to sneak under and pop it up. It comes off quite easily.
3. You should now be able to see the bulb and the connectors. I don't know the technical names, but the two metal connectors are thin, pretty flexible tabs with 3-4mm diameter holes in them that allow the pointed ends of the bulb to sit in them. At this point, you can remove the old bulb.
4. Comparing the old bulb with the new (mine was the same size as the rear dome light), you'll see that there is a pretty obvious size difference. The LED is longer. Studying the switch mechanism, you will find that turning on the light actually rotates an entire tab, moving the bulb with it. For this reason, you will not be bending the switch-connected tab.
5. Instead, simply push the tab on the opposite end of the switch backward, bending it away from the other tab. You should be able to sneak the LED into that side first, then fit it pretty well into the switch-linked tab.
6. Test the new bulb by turning the switch. If it looks good, pop your grey C-piece back in place and reconnect the wires. Pop the whole assembly back into place and you're done!
Overall a lengthy guide for what I was able to figure out without much effort, but hey. Just doing what I can.
Old 11-01-2006, 09:53 PM
  #310
Magnus213's Avatar
Finally got my digicam to work again, so here are a few pictures.
Comparison of stock map light and LED (guess which is which):
All three LEDs installed:
Map lights, with cover:
All three, with cover:
View from the front of my car, PIAA Xtreme White parking bulbs as well.
Old 11-01-2006, 11:09 PM
  #311
JaN_MiChAeL_07's Avatar
whered you get those parking lights from ??
JaN_MiChAeL_07 is offline
Old 11-02-2006, 12:16 AM
  #312
haiduy's Avatar
wow i want blue lights for my front and back now =D
haiduy is offline
Old 11-02-2006, 12:22 AM
  #313
Magnus213's Avatar
Cardomain Store! Here's the link...
http://www.cardomain.com/item/PIA19172
Old 11-02-2006, 12:28 AM
  #314
cool thanks ....
Old 11-02-2006, 12:33 AM
  #315
haiduy's Avatar
kool i just ordered the LED lights for my car =D 19 dollars T__T for 4 LED lights and all hopefully it would be nice
i got all white
haiduy is offline
Old 11-02-2006, 12:49 AM
  #316
this is why i make things myself...
Old 11-02-2006, 12:58 AM
  #317
haiduy's Avatar
hahaha oh well =D hopefully a good investment
haiduy is offline
Old 11-02-2006, 01:02 AM
  #318
it should be
Old 11-05-2006, 06:48 PM
  #319
haiduy's Avatar
haha i just received my leds in on saturday, dayam that was quick 2 day to mail woot love you LEDS =D now ima install them hopefully everything goes well
haiduy is offline
Old 11-05-2006, 06:59 PM
  #320
don't twist....
and people wonder why they made a "how to" on replacing a light bulb in a car....
this is about the only time where my "twist, remove, replace" does NOT come into play.
just remove and replace for the front and rear domes... and maybe the trunk light too.. sure.. and yea..
Quick Reply: Dome Lighting Install
