Dome Lighting Install
#402
Originally Posted by esisso
Originally Posted by CSOCSO
btw wich one did you bought?
i had the 5 leds (4 on side 1 on top) and this is what i ordered again.
and this is what i have in the front lights
#405
Many pages back you'll see a pick of someone's license plate with one 6LED bulb and one single 1Watt LED (the super-duper bright one). It looked pretty good with the super-duper bright LED (lower color temp). I'll prob use those if/when my 5led bulbs go out, but that's pretty hard unless they get wet?
And FYI, I just swapped my coworker's trunk light in his IS350... its the same exact light housing as our tC! =)
#407
Originally Posted by Need4Bass05
I just ordered mine the other day, will post pics when I get them installed. I ended up buying 2 white and one blue for the front and a blue festoon for the back.
let me know how to blues come out!!! i have blue front and rear but they have different color i mean.. they are blue.. but the rear one is darker and the front one is like blue with a hint of a green!
so if your front blue is dark like the rear one then let me know wich one did you buy to the front! pls! thanks!
#408
quick question - i just tried installing the LEDs and I got the front 3 done but when I went to put the festoon bulb in the back dome light, it seemed way too big. I read it's supposed to be a little bigger than the stock but it wouldn't fit & I was a little nervous to force it in there. I got the bulb that's on page 1. Any help with this would be greatly appreciated.
#413
Sort of off topic and I can't seem to confirm. But I want to switch out the trunk light in my tC and the cubby light. Is the cubby a 194 socket led bulb? And can I use the festoon bulb in the trunk like I did with the rear dome?
I'd like to order today and get this out of the way..
Thanks guys!
-cz-
Thanks guys!
-cz-
#416
Just wanted to get a few things straight b4 I order.
For Dome Lights = I use 3022-x4 LED Festoon bulb
for the Map Lights I use = WLED 6-LED bulb
12 VDC 6-LED Wedge Base bulb (194/168 type)
For Trunk Light I use = 3175 bulb ( But I cant find a link on that site to any bulb that says 3175)
For Cubby Hole I use = T1.5 Instrument LED bulb
