Dome Lighting Install
#602
If you want bright, either go with the 1 watt LED or a size 921 LED bulb for the parking lights.
I have the 1-watt 168 bulb with built-in heatsink for the parking lights and have lasted for several months now (05-07 tC's tend to burn out LEDs when used as parking lights).
Oznium has LED arrays for the domes that work pretty good. I used a red one for the rear dome. I used white 12-LED 921 bulbs for the map lights which are pretty bright (originally tried them for reverse lights, but not enough useable output). I used a 1-watt LED for the front dome and it's decent.
#608
after I switched the bulb in the trunk/hatch, the LED in my front dome light now flickers. Its the main dome light, not the pilot lights, and it flickers when its on, not when its fading in/out. I dunno if its a pure coincidence, or some how I caused a short or something, but its annoying to have that light flicker.
I guess i'm going to get more LEDs and replace that one. Hope that does the trick. I need to swap the lights in my license plate anyways....
#609
so for the front dome light i'm looking for something superbright and white.... this is the right one yes?
http://www.oznium.com/led-domelight
im looking for the same thing for the map lights as well... i was going to go with a couple of these from superbrightleds.com
921-x12 Wedge Base LED bulb
what about the front parking lights.. the little tiny bulb, which bulb you guys recommend?
#614
Originally Posted by Yanki01
just went on superbrightleds.com to check them out. Havent been on in a while. Saw a couple of bulbs that look interesting to me and i might try them out....
for the rear.....
for the fronts (they come in 3300k and 8500k. Ill get one of each)
im gonna order them, should get them sometime next week. Ill post some pics of the difference.
for the rear.....
#616
Originally Posted by Cpt_Buttchin
You, sir, have made superbrightleds.com a good little score in the past couple years, from the looks of it. I'm about to buy 'em myself. Thanks a lot for the simple, well-written instructions.
#618
Originally Posted by tCeeder
Yanki, which do you recommend for the front domes (all 3 sockets) for the whitest, brightest output?...
#620
in 8500k
or these:
WLED-WHP Pure White High Power
or these...
in 8500k
or these:
or these...
1) i wouldnt go with the first one because that has nothing to do with the front dome lights........... that light has a 360 degree viewing angle.. its the best led for the parking light or the license plate.. but you dont need wide viewing angle in the dome lights.
about the other two........ i got the one with the 12 led.. i never seen so bright led like this.. the only brighter is the one from oznium with 20 or 25 led or so...................
for the front dome lights get the 12 led one!!!!!!!!!!!! for the license plate light get the wide viewing angle one!
