tC Tech and DIY Info for the Scion tC
Dome Lighting Install
Old 10-11-2005, 09:41 PM
  #81
fishingexpert87's Avatar
omg i just got all the bulbs with the same setup, and it only took me 10 min. easier than i expected, would have been quicker but the back dome light took a bit to push in!
fishingexpert87 is offline
Old 10-11-2005, 10:08 PM
  #82
Mmartin_47's Avatar
Does anyone know if there are other sizes that are bigger that will work for sure?
Mmartin_47 is offline
Old 10-12-2005, 03:42 AM
  #83
CatalepsicFox's Avatar
if you find the size of the bulb... superbrightleds.com actually has measurements for the festoons that would always usually works. Even if it doesn't fit you can sometimes stuff it in as long as you are careful.
CatalepsicFox is offline
Old 10-12-2005, 04:08 AM
  #84
gcxandy's Avatar
good write up .Was just gonna order from sujperbrightleds. now this makes my job easier =D
gcxandy is offline
Old 10-15-2005, 05:32 PM
  #85
DOWNSHIFT's Avatar
I had to pull apart the whole peice as 2 bulbs got stuck as i turnend them by accident and pushed them up.
Was kindda dissapointed when i installed them, but turned them on at night and was amazed how bright/clean looking the light is
DOWNSHIFT is offline
Old 10-18-2005, 03:26 AM
  #86
WingspanTT's Avatar
DUDE I just did this mod - thanks so much... at first I was nervous about the bulbs but I got gloves and they wiggled out like a charm. My tC looks sweet now thanks!!!!!!!!11!1!one!!1!
WingspanTT is offline
Old 10-18-2005, 09:47 PM
  #87
hell yea, i did mine too same set up. my tc=hot
Old 10-22-2005, 05:56 AM
  #88
hippo's Avatar
which rear dome lights to get 31x10mm or 30x10mm?
the 31x10mm is 2 LED while the 30x10mm is 4 LED. So would both fit otherwise?
hippo is offline
Old 10-22-2005, 06:01 AM
  #89
yescadog's Avatar
thanks for the info....i like the led's for the dome lights
yescadog is offline
Old 10-23-2005, 10:03 PM
  #90
Jlevi's Avatar
Hmm we have the ones for the front (ours are a little brighter hence the higher price) but we no longer carry the ones for the rear... maybe next time we reorder LEDs we'll get some though.
JL
Jlevi is offline
Old 10-31-2005, 11:16 PM
  #91
adamn918's Avatar
ok so i did my front dome light no problem but then when i got to the rear dome light i popped out the stock light and was putting in the LED and it sparked... now none of my dome lights will turn on! does anyone know if i blew a fuse and if so what type of fuse is it that i replace the old one with and where the flip is it? lol
adamn918 is offline
Old 11-01-2005, 12:09 AM
  #92
rwf
rwf's Avatar
hey guys, do anyone kno if u can change the lil bulb in that compartment below the center console to blue led? if so, how?
rwf is offline
Old 11-01-2005, 04:02 AM
  #93
7thgear's Avatar
it's fairly easy, if you do it the right way. don't try to use a little tweezer and pull the bulb out. you'll end up either breaking it or being very frustrated. what you want to do is from the passenger side, there's a hole to the left of the center console where your feet are placed. reach in that hole, you'll feel a wire. run your hands along that wire, up to the little cubby hole. pull and wiggle that thing out and you can actually pull the whole wire back out so you can see it ,but it stops/ends right at the hole. just pull the bulb out and put your desired color bulb in there. it uses #74 incandescent bulb also found at autolumination and superbrightled.com.
7thgear is offline
Old 11-01-2005, 05:59 AM
  #94
rwf
rwf's Avatar
ahh, thanks for the info!! ill try that~
but um.. sorry for askin the obvious, but is this bulb the rigth one?
T1.5 Instrument LED bulb
1-LED Instrument Cluster and Gauge illumination bulb. #74
i just want to make sure b4 i order it >_<
rwf is offline
Old 11-01-2005, 07:14 AM
  #95
SquashJV's Avatar
good job looks good
SquashJV is offline
Old 11-02-2005, 10:38 PM
  #96
7thgear's Avatar
don't know.. but use this though.
http://autolumination.com/74.htm
#74 (T5, T1-3/4) bulbs are 3/4" x 1/8" diameter
this is what i ordered.
7thgear is offline
Old 11-02-2005, 11:51 PM
  #97
rwf
rwf's Avatar
does #74 leds work? or only the incandecent ones?
rwf is offline
Old 11-03-2005, 02:02 AM
  #98
7thgear's Avatar
leds work too, but just make sure it fits into that little hole though. it seems that only the incandescent bulbs will fit, but i could be wrong.
7thgear is offline
Old 11-03-2005, 02:04 AM
  #99
7thgear's Avatar
unless you plug it in from the front if it doesn't fit from behind... that is.. if your hands are small enough.. it's a tight fit.
7thgear is offline
Old 11-03-2005, 04:13 AM
  #100
7thgear's Avatar
but the ones that you are ordering already comes with a base. you don't need the base though.. only the bulb itself comes out... unless you can pull that led out....
7thgear is offline
Quick Reply: Dome Lighting Install
