HID Retrofit (Custom)
#44
very small update with the freshly painted trim piece. I started drilling holes to mount the projector but didn't get very far because the curved reflector makes it difficult. i got some nylon spacers and will use those to help. i'll have pictures of those later tonight.
i used duplicolor hi-heat aluminum silver paint. it doesn't match the SSM color, but it was the closest match that i can find locally.
as for bezels, E46 bezels fit perfectly. its like they were made for it. but expect to pay around $80-$100 for a pair of those.
#46
i didn't get anywhere tonight with the mounting. the reflector is a pain to mount the projectors onto. i need to get some bigger size washers tomorrow after work. i'm starting to think that i might have to cut the entire back side of the reflector off and attach a flat metal plate in its place. thats what i did on my maxima and mounting the projector there was a whole lot easier afterwards.
#49
Originally Posted by SassyScion
Nice update! The paint job looks nice. Will the amber light through the silver painted side reflector? I'm trying to figure out how that will work.
#52
you mean E46? or E55? one is the 3series bmw and other is a mercedes. either way, you'll need the projectors, bulbs, ballasts and shrouds or bezels.
i think both would be easier to do than the tsx i'm doing. the tsx projectors is like 5" wide at the middle and is a pain in the @ss to mount. after a failed attempt at mounting onto the reflector bowl, i finally cut out most of the reflector and will be sticking a mounting plate on the back instead. i'm gonna cut holes in the plate tonight and should be able to update with pictures. i spent the last few nights trying to mount onto the reflector w/o luck.
also, although the E46 and E55 projectors are easier to mount, the output will be inferior to the japanese projectors, but still many times better than stock halogen.
#55
Originally Posted by freeflowing
yeah thats what i meant e46. how much do you think i should pay for the whole setup. i going for an easy install that i can accomplish in less than a 3 days.
#60
1. I have a couple questions. Like when mounting the projectors how do u know there being mounted level? How would u test them.. i mean if iam in my house how would i plug them in?
2. when prying the headlights open are they very fragile?
3. if i have an s2000 headlight (the whole light) does that have a bezel. (which i can use?)
4. And wiring in angel eyes? where do i wire them into? Do i need anything else?
Iam sorry but iam getting everythign together and just wanetd to know these things b4 i started. Any other advise is also great.
