tC Tech and DIY Info for the Scion tC
LED Swap Diagrams (Gauges / HVAC)
Old 01-14-2007 | 07:05 AM
  #41
SquallLHeart's Avatar
Originally Posted by thespottedcow
Do you have a diagram for the radio leds? and also, does the steering wheel controls just pry off the steering wheel? how exactly does that work. btw my gauges look very nice, ill see if i can get some pictures posted later.
radio:
there are pictures on the other pages... look thru the article
https://www.scionlife.com/forums/viewtopic.php?t=84661
steering wheel controls:
https://www.scionlife.com/forums/viewtopic.php?t=91321
more than just prying.
Old 01-15-2007 | 07:20 PM
  #42
Yanki01's Avatar
good job, now i just need to find the ***** to do it!
Old 01-16-2007 | 12:43 AM
  #43
Garage1217's Avatar
<< Owns a set of those *****, I can swap your stuff anytime!
Old 01-16-2007 | 12:51 AM
  #44
Yanki01's Avatar
<---- me and her are thinking about you doing the swap
where are you located?
Old 01-16-2007 | 01:11 AM
  #45
Garage1217's Avatar
I am located in Arizona. I do a ton of mail order and would be happy to rock your gauges for ya!
Old 01-16-2007 | 02:15 AM
  #46
Yanki01's Avatar
pm'd you
Old 01-16-2007 | 05:31 AM
  #47
bluetc2005's Avatar
yeah...I am not really good with soldering...I tend to make a mess...who is making these kits installed to buy?
Old 01-16-2007 | 06:02 AM
  #48
Yanki01's Avatar
knowone makes a "kit". You have to send it to one of these LED gods on here and they do the swap for you.
Old 01-16-2007 | 06:42 AM
  #49
7thgear's Avatar
if we swap out the led for the the little red light that blinks with the key next to it with a different color, will it still blink? sorry, i totally forgot the name of it.
Old 01-16-2007 | 06:46 AM
  #50
Garage1217's Avatar
Not sure which you are talking about. I offer a parts kit with diagrams, but you have to know how to solder and have solder supplies in order to make the kit work.
Old 01-22-2007 | 05:02 AM
  #51
Garage1217's Avatar
Bump! XA diag is done and in the xa forum... XB soon to come!
Old 01-25-2007 | 05:40 AM
  #52
magyver's Avatar
what is the blue wavelength of your led's? i've see the blue led in person and wasnt my taste. i want a deep ___ blue look.. any info?
Old 01-25-2007 | 11:25 AM
  #53
Garage1217's Avatar
With leds you will generally not get a deep blue, however I can prodce a deep almost navy blue as a custom color. General wavelength is 475nm.
Old 01-25-2007 | 09:09 PM
  #54
magyver's Avatar
custom sounds expensive... no?
Old 01-26-2007 | 12:18 AM
  #55
Garage1217's Avatar
Custom colors run about $25 more in general.
Old 01-27-2007 | 06:32 PM
  #56
woffledong's Avatar
so where about are the leds for the needles? are they in the gauge leds cluster? i wanna only do the red on the high end of my tach and speedo. thanks.
Old 01-27-2007 | 06:54 PM
  #57
Garage1217's Avatar
That is a question I get all the time, the needles are not lit by seperate LEDs, they are lit by the same leds that light up the gauge cluster. People tend to think they can change the needle color by simply swapping an led under them. Not so, you have to paint them or change them colors by a few other methods...
Old 01-27-2007 | 08:42 PM
  #58
woffledong's Avatar
well i figured they were the same one, do you know how the needles change from one color to the next when your tach gets to about 3500. is that from wiring the furthest right led red or is it a paint trick?
Old 01-27-2007 | 09:23 PM
  #59
Garage1217's Avatar
It is a simple light filter trick on the gauge surface. If you choose white needles, I offer the RPM change free.
Old 01-30-2007 | 12:30 AM
  #60
Riceburner98's Avatar
Just had to say, I did the swap last night and DAMN it looks better in person than in the pictures! I tried white but changed to pretty much all blue. Swapped around colors in the idiot lights and HVAC status lights including the fading temperature ring (that's AWESOME in person!)... Not a hard thing to do, and VERY well worth the time spent! Good job on the diagrams, I'm sure they'll help lots of people to come! While I was in there I doubled up on the odometer and HVAC LCD LED's, don't know if anyone else is bothered by the "bright spots" on the LCD screens or not.. (I could always see that there were 2 LED's on the odo and 3 on the HVAC) So I equally spaced 4 for the odo and 6 for the HVAC, and now it's a nice even light. But a PITA to do! Keep up the good work!
Quick Reply: LED Swap Diagrams (Gauges / HVAC)
