tC Tech and DIY Info for the Scion tC
Painting (Wheels)
Old 05-17-2007 | 11:07 PM
  #81
joea7x's Avatar
and... did you use primer?
Old 05-17-2007 | 11:08 PM
  #82
nameless_ak's Avatar
this would scare me. wheels are to expensive to take a sander to ah.
Old 05-17-2007 | 11:13 PM
  #83
BeetC's Avatar
1UP Crew
Originally Posted by joea7x
how much did u sand it down? just enough so that the paint is gone? i bought some new wheels and tires off this guy and he had masive curb rash but the tires were new so im going to paint them since i have an extra set of wheels. i have to fix the crub rash with some bondo first. im doing it this weekend ill post some pics when im done.
Sand the wheel enough to scuff the finish so the paint will grip. I didn't use any primer, but it can't hurt anything if you do.
Old 05-17-2007 | 11:24 PM
  #84
joea7x's Avatar
what do u mean by scuff haha sorry im a newb and i dont want to screw it up.
Old 05-18-2007 | 12:40 AM
  #85
comedykills's Avatar
ScionERA
Scionetics
you have to take the clear coat off the wheels w/ 400 grit fine sand paper
Old 05-19-2007 | 04:41 PM
  #86
joea7x's Avatar
how the heck did u tape it. i tried masing everything off. and that was a bummer it would not stick!!!!!
Old 05-22-2007 | 10:26 PM
  #87
yelloxtc's Avatar
Heres the supplies:
cleaned the rims inside and out with soap and water only and let dry:
Taped and primed the rims only. No sanding cuz it took too long:
Finally I sprayed the inside wheel well first with one thin layer and then I did the out side last with a thin layer:
For best results I sprayed the outside lip first and then moved inside. Ill do second coat later and then gloss. Oh yeah i didnt even use the enigine degreaser so i returned that and got another can of white primer cuz i ran out. More piks of the finished results later. Payce out
Old 05-23-2007 | 01:08 AM
  #88
BeetC's Avatar
1UP Crew
Looks great! That's a lot of cans of paint! Did you use all of it? I only used like 2 cans...
Old 05-23-2007 | 06:58 AM
  #89
ScionERA
Scionetics
thats about what I used ....actually a little less then what I used since my whels are 2 colors ........ those look pretty good for being gold
Old 05-28-2007 | 11:44 PM
  #90
richardsayzz's Avatar
hmm what should i do to get a glossy black finish? powder coat or paint...hmmm anyone got a picture of all black powder coated ?
Old 06-03-2007 | 03:34 PM
  #91
DiStUrBeD_AzN's Avatar
Unique Scionikz
Hmm... I am about to paint mine black again, I want to give it a nice glossy black. Would you want to sand or primer Steelies?
Btw, what is the best paint to use for the wheels? I don't want it to chip or anything. >_>
Old 06-05-2007 | 03:35 AM
  #92
Iride_xB04's Avatar
so you dont have to sand it?
Old 06-06-2007 | 02:17 AM
  #93
yelloxtc's Avatar
I didnt sand the original rim whatsoever. But that can run the risk of paint not sticking to the wheel properly under high heat conditions.
I dont drive around much on my stockies so thats why I decided to go with a non-high heat condition paint. It might chip off and it might not. We'll have to see but here are the pics of the finished wheels.
Oh yeah and everything i bought could be purchased at your local wally world. Gold paint, white primer, and clear coat enamel. I returned the duplicolor clear wheel coat cuz it sucks.
Old 06-10-2007 | 08:13 PM
  #94
freestyle789's Avatar
get them on your tc and take pics! i wanna see !
Old 06-10-2007 | 11:37 PM
  #95
Unique Scionikz
How do you know these suck? I bought those already figuring it would work better than regular clear coats. >_< Should I return it?
Old 06-11-2007 | 07:24 AM
  #96
yelloxtc's Avatar
I know its not the clear coat i wanted because when i sprayed it on a test surface, it came out milky white and i could barely see the gold underneath. I thought it was going to be see through crystal clear but it was very hazy. so i returned it and got krylon triple thick crystal clear coat spray.
Old 06-12-2007 | 07:25 AM
  #97
marx_tc602's Avatar
looks real good. I'm gonna have to do this, because sanding does take too long. But I'm gonna have to buy high heat paint, because livin in Phoenix, something is bound to melt.
Old 06-13-2007 | 12:05 AM
  #98
yelloxtc's Avatar
Here's the moment of truth.
Old 07-01-2007 | 04:20 AM
  #99
DeFinity's Avatar
What do you guys think about white spokes on a FM? I have white grilles white headlights, white grille lights, white underbody to come, and white stripe underneath the top grill down to below the bottom grill, the width of the grilles. I work at a body shop so all the paint i do is proper for a car and I can order rim paint for it. Plan on doing some white on the hood, but not the whole thing.
Old 07-08-2007 | 12:13 AM
  #100
whats up guys, im painting my rims tomorrow, and have a couple or questions........im sanding the wheels and bought 800 grit, should i have gotten 400? im going to prime the rims after i sand them and i have some scratches in my rims so i bought duplicolor filler primer, will that work ok? and i want to clear coat them any reccomendations of what clear coat to use? thanks guys !
