Radar Detector Install (Hard Wire)
when cops are parked to the side of the road they have their radars constantly on, they are not shooting every car that passes by. As soon as one car goes too fast they will be alerted. A good radar detector can detect such speed traps from so far away that cops wouldnt matter to you.
^^ true. I was lasered a few weeks ago and I wasn't even paying attention to my speed because I was too busy talking to my girlfriend haha. Even though the V1 notified me, good thing I was only going 5 over.
radar waves are not affected by tint very much, radar passes through objects such as metal, glass, fabric and even your own body fairly easily, it is just reduced and the reflections back are dramatically reduced.
Now laser is a completely different story.
laser is light, pure and simple, just on a certain wavelength. (700-900nm I believe, red beam) and tint absorbs/reflects light, so your 5% tint will absorb/reflect 95% of light hitting the window (theoretically) in addition to the stock window tint all around of about 75-80% so that would make a total VLT of about 3.75%. Meaning if I point a laser at your window, only 3.75% of that laser light is going to pass through (aka hit the detector)
But I sure hope you don't have 5% tint on your windshield....
So in short, YES a radar detector would work, but its laser ability would be severly hindered by your tint from the sides and the rear (radar/laser cannot get a speed reading from the side)
I am no expert in this but fuses are in amps i believe. Just take at look at the manual of download one from their website.
http://www.cobra.com/pdf/RADAR/ESD9560_manual.pdf
Bottom of page 22.... 1 amp
RYS, I need your help
Can you go more in depth explaining your statement, "(The sunroof already has a fuse, so if the V1 wire shorts, it'll blow the fuse for the sunroof). " Is the wiring shown in this post done after the sunroof fuse? If so, is it possible to do it before the sunroof fuse?
Thanks for your help
Re: RYS, I need your help
Any event that would have caused the V1 inline fuse to blow, will now cause the sunroof fuse to blow instead.
This is good because you don't want to have to take everything apart again to replace a blown fuse.
Make sense?
-Brian
Originally Posted by 06SuperWhite_SoCal_tC
IMHO, Radar detectors are not worth the money. They only tell you when Radar is being used. By the time it lets you know Radar is being used, guess what, it's to late. Cops are trained to shoot the Radar within only enough time to read the cars speed. They don't sit there and hold the button, shooting every car in sight. They are trained better than that. Also, when they do pull you over, they are going to be less likely to take it easy on you seeing as you're trying to one up them with a Radar Detector.
Another point, I got popped by lidar once on a night when it was pretty much only me on the freeway. I immediatly lowered my speed, and finnaly saw him pull onto the highway and flip on his lights. I pulled over, and unplugged my V1. He came up and asked me if I knew how fast I was going, which I responded that I didn't really know(the truth). He then asked me where I was going and for my license and registration. Told him I was on my way home, he handed me back my license and registration and said to slow down. Never even pulled up my record from what I could tell. He had to have seen my V1, yet he still let me go with just a verbal warning. Lucky I guess?
Make sense?
-Brian
Moral of the story: Keep the inline fuse.
Originally Posted by ThePerchik
Good Answer there but i think its better to leave the inline fuse. If the sunroof blows its fuse in the fuse box for some reason it will kil the radar and the sunroof. Replacing the fuse in the box will allow both to work. If the radar blows its inline fuse it will stop working but the sunroof will still work. BUT, to change the inline fuse you will have to get all that stuff from the top to get to the inline fuse. The reason that the inline fuse is a good idea is just a matter of amps. If the inline fuse and the sunroof fuse (AND I AM PRETTY SURE THIS IS THE CASE) do not have the same fuse rating then you rust blowing the radar to poop if there is a surge because the sunroof fuse did not pop and there was nothing protecting the radar.
The radar detector should be designed to accept up to 15 or 16 volts. There should be an internal voltage regulator to handle this. So you should not have to worry about if the V1 fuse and the Sunroof fuse are the same amperage.
If anything the V1's fuse will be less because it does not require the same amount of power as the Sunroof.
The other point is that if you wish to wire the V1 in a way that will not blow the Sunroof's fuse in the event of a V1 malfunction, you will need to find an unfused ignition controlled point of power. This means pulling the driver's A pillar and running a line all the way down to the fuse box, then finding the non fused ignition power. (By non fused, I mean non fused interior side, there is another fuse for power in the engine bay.)
It's just easier to run it off of the Sunroof's power, and accept that if the V1 or Sunroof blows the fuse, you will have to replace the Sunroof fuse before either of them will work again.
I don't think anyone has had a problem with this since this was posted. I sure haven't, and I've done this to 4 vehicles so far. (Mitsubishi Eclipse, Mitsubishi Galant, Scion tC, and my Lexus IS350.)
-Brian
thanks Rys
Thanks for the info, there's a lot of good stuff in the above discussion. I think I will leave the inline fuse in there even though it will be a bigger hastle in the even that the V1 fues goes. I figure it's better safe than sorry even though I would expect that those that are more electricly inclined would disagree with my decision. I've never had the V1 fuse go and figure I'll take my chances that the inline fues won't go.
Peace
Peace
Re: thanks Rys
Peace
Peace
Great article. As I read it, I found Myself wondering if I could also do the same thing with a GPS system. And taking it one further, would there be any complications of wiring up a GPS and a Radar Detector at the same time from that point?
