Radar Detector Install (Hard Wire)
#63
i tried to hook it up with the orange cable. but it won't power up. i use a volt meter to check and make sure the cable and ground is good. and it reads 12.5 v. and i also check the radar and make sure all the cables and radar are working. but somehow it won't power up. what could cost the problem? anyone know?
#66
Are any of those other wires 5 volts? I want to do something similar with my tom tom but it only needs 5 volts/2amps.
Would any of those other wires work or would I need to tap the 12volt one and then use capacitors or something to reduce it down?
Thanks
Thanks
#67
First of all, you would need resistors to lower the voltage that the Tomtom would see. I don't know personally if any of those wires are 5V. The easiest thing to check is to get a voltmeter/multimeter and test the different wires up there. However, if you need to convert the 12V to 5V, here is a schematic of what you would need to do:
The bottom left equation is a derivation using Ohm's Law to calculate the resistance needed. The bottom right is a calculation showing the power that will be dissipated across this resistor (power is current times voltage). So, since 14W will be left off by this resistor, you should use a resistor that can handle at least that. That'll probably be a 20W 3.5ohm resistor. (Check partsexpress.com if you need to order online)
Here's a question for all you radar users: What's the optimal mounting location? I want it to be fairly discreet, would it be best to be on slightly above the dash on the windshield, or up by the rearview mirror?
#71
Good read, and in response to some of the things on page one I bought an Escort 9500i and I have never gotten a ticket with it. You have to be an safe driver, it isn't a sure fire thing. I go about 80, if I see it I casually slow to 75. And about the tickets when having one, I'v been pulled over quite a few times and have yet to had a cop frown about me owning one, if you're going 95 when you get pulled over and you have one I'd be it's a different story.
#75
It seems as if this is dead, but I attempted hardwiring my V1 today, followed the directions, and for some reason it isn't working. Unfortunately, I don't have a volt meter, so that is doesn't help whatsoever, but unfortunately I can't figure this out. The ground is snug and fitting tightly with the bolt, but I am assuming that either the T-Tap isn't sung enough to the wire, or I'm tapping into the wrong wire. Anyone else have a similar problem?
EDIT: The problem was the wire attached to the T-Tap was being pushed into the T-Tap itself, and it would cause it to lose power. After messing around with it, I got that wire stable in its connection, and it works flawlessly. Thanks for the AWESOME guide. V1 is recommended heavily, as well!
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 01:34 AM
my06tc
06-25-2015 01:18 AM
TheRedBox
31
12-02-2003 05:53 PM
