tC Tech and DIY Info for the Scion tC
Subwoofer / Interior Lighting Install (OEM)
Old 08-17-2004 | 06:12 PM
JasonH's Avatar
Originally Posted by iowagary
I think I should get a nylon panel removal tool - can you get something like that at home depot?
I don't know, but I don't think so. maybe at an auto parts store, or even from your dealer, I suppose.
I don't have a rivet gun - what in the installation do you use it for?
You attach the lights under the dash with the rivet gun.
How many things are you drilling holes in?
For the lights - one hole for the switch plate, two for the cupholder lights, four for the mounting of the light tubes.
For the subwoofer - none, really, but you need to make a hole in the carpeting to put the bolt through. Also, if you want to wire a switch like mine, you need to drill a hole in the switch plate.
I've got the cordless drill setup and all that. I should probably get a step bit - is that the one that enlarges the hole as it goes?
Yes, that's a step bit. Mine goes from 3/16" to 7/8".
Old 08-17-2004 | 07:12 PM
iowagary's Avatar
Ah... a switch to turn the sub on and off. I think that's a good plan. I doubt I'm going to do the lights, so I guess that simplifies things. Maybe I'll ask my dealer about the vinyl tool, or shop around or something. As for switches, is Radio Shack the place? It would be nice if I could find a really cool or nice looking switch - maybe even with a little LED on it or something?
Old 08-17-2004 | 09:04 PM
JasonH's Avatar
I got mine at Radio Shack, but I didn't want anything fancy. They didn't have a great selection, but I didn't care. If I wanted something special I would have looked online.
Old 09-06-2004 | 04:36 AM
lriicelboy's Avatar
Can you please just do a write up tutorial of just the Interior Light Install please?? I'd very much appreciate it.
Old 11-10-2004 | 06:43 PM
Janizary's Avatar
In reading this it does not appear to me that you have to make a separate power connection from the sub into the engine compartment. I am correct that that power for the sub is coming through the harness to the head unit?
Old 11-10-2004 | 06:54 PM
iowagary's Avatar
You are correct. The stock speaker harness unpluggs from the deck and plugs into the sub harness, which then plugs into the deck. It's a daisy-chain type arrangement and all the power flows through that.
Old 11-10-2004 | 09:18 PM
Janizary's Avatar
Thank you very much for the reply. That makes it handy for me to do then
Old 12-18-2004 | 06:52 PM
toyota_scion_tc's Avatar
I didn't get a lot of feedback on this one, so I wanted to bring it back to the top. Did you like this write-up? Did anybody have any questions? Thanks.
good write up. 1 question on the sub. I did notice any from the pictures but are there any kind of amp adjustment on the sub. I know it has the gain adjustment on the front. Like adjusting the crossover or anything?
Old 12-18-2004 | 08:28 PM
iowagary's Avatar
Nope - the only adjustment for the sub/amp (on the unit itself) is the gain ****. It could really use a crossover, but you can make do with the gain and the adjustments on the head unit.
Old 01-11-2005 | 02:12 AM
armadajs's Avatar
that was a great how too but i was wondering what the best place to hook the remote wire to would be if you didnt want to use the switch
Old 01-11-2005 | 03:51 AM
iowagary's Avatar
If you didn't want to use the switch, you don't do anything. The remote wire is part of the sub harness. The stock head unit harness daisy-chains into the sub harness, which plugs into the deck. If you're not adding a switch, you don't have to do anything.
Old 01-12-2005 | 02:00 AM
armadajs's Avatar
thanks for the answer to that question i appreciate it
Old 01-24-2005 | 02:52 AM
natodog's Avatar
how deep is the box, im looking at putting in a soundstream 500 watt sub, but its magnet is 6 1/8in. deep
Old 01-24-2005 | 05:22 AM
utatc7218's Avatar
how does the sub sound?? Does it just make up for the lost base or can you feel the sub when its turned up?
Old 01-24-2005 | 06:04 AM
iowagary's Avatar
If anything, the sub is almost too powerful. It definitely overpowers the mid section of the stock stereo - bumps pretty good. Only for hiphop could you use possibly deal with more. Sounds good for electronic and is usually more than enough for more rock-type stuff.
As for the depth, I doubt you could fit something that deep in it - it would be stupid to buy it for that since you're paying for the amp in there too.
Old 01-25-2005 | 01:02 AM
YELLStC's Avatar
Great install tips. In your pictures of the back of the head unit, you mentioned the connector on the right side is the one for the sub. Is it the right side as you are looking at the picture (next to the antenna)? or is it the right side as if you are sitting in the car ? . I am trying to locate a wire kit for an aftermarket sub and amp.
Any help would be great.
Thanks,
Old 01-29-2005 | 12:06 AM
yesti's Avatar
Default Re: Spare access
Originally Posted by blitzcat
Once the sub is in, does it not get in the way of opening the spare tire well?
No, it doesn't. This I know for a fact.
Old 01-29-2005 | 12:18 AM
iowagary's Avatar
Well... in a way it does, especially if you have the cargo mat. The board on the bottom in the back is hinged in two places. It partially covers one of them. To get it out, there is a little fold-and-slide action going on, but it's definitely doable. The sub isn't actually resting on the floor - it's like 3/4 of an inch up, so you can slide things in and out. Once you know how the clips work, you're fine,.
Old 01-29-2005 | 02:16 AM
yesti's Avatar
yeah, but that beats doing what is on that paper they give you at the dealer about taking the box out to access the spare tire. when i saw that i was in disbelief.
Old 01-29-2005 | 02:24 AM
iowagary's Avatar
Yeah... if you've installed the sub, you know how ridiculous that would be. In order to take the box out you have to pop the cover off (which is hard in and of itself), unscrew and disconnect the actual woofer, undo two bolts that are REALLY hard to tighten unless you're a contortionist, pull the box out, and disconnect the cable harness. I'm really glad you can just move the mat out. If you had to do all that, I don't think I'd like the sub nearly as much, even though I've only had one flat in my life.
